Ana içeriğe geç
The Chevrolet Aveo (T200) is the first generation, a subcompact automobile manufactured since 2002 by Daewoo — originally marketed as the Daewoo Kalos and prominently marketed as the Aveo.
26 Soru Tümünü görüntüle
Front left power window can roll down but it cannot roll up,
My Chevrolet AVEO LS . Front left power window can roll down but it cannot roll up, and does not respond from drivers main switch at all,not even going down.After proper testing of both F/ Passenger and main switch driver side found both working switches in good working order.Any advice or suggestions please. It is a 2007 Model
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
Hi,
What is the year model of the vehicle?
tarafından
If I fully understood, your wheel drive is in the right, and the switch near the driver don't work on the window of the left side and the switch on the left side only roll down the front left window, is that correct?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Here’s the Chevrolet Aveo 2007-2010 Factory Repair Manual
Scroll down and click on Schematic and Routing Diagrams > Fixed and movable windows, then pass the security test to view the schematics for the power windows.
Use the schematics to check if there is power available at either the driver switch or the passenger switch to operate the window regulator motor in both directions. The wire colours are shown on the schematic
If there is power at the passenger switch then click on Main Contents > Interior trim and paneling to see how to remove the door trim and then click on Main Contents > Fixed and movable windows to see how to access the power window regulator(see p.27 of 44) to see if the regulator motor connections are OK etc.
Hopefully a start
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Rudi Le Roux sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 2,057
