Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Soru Tümünü görüntüle
iPhone not booting on battery but works on plugged in?
iPhone 5 it won’t boot, when i switch on apple logo comes for 5 seconds and goes off, and it repeats the same boot 20 times, then it says battery with red bar 1%, and goes off,
but instead when i plug my USB cable to power source/charger it boots successfully, and battery charging as usual 70%, everything works fine, after 100% charged, when i unplug my cable again, problem occurs-boot loader,apple logo 5 seconds, repeats upto 20 times, and battery red bar.
again when i plug charger it works, but when i plug my USB to laptop, it won’t boot,
WHY?
i checked all the hardware’s, checked battery voltage: 4.17v with multi meter. battery is perfect, hardware are no dust or clean,
I updated & restored phone via ITunes, the problem not fixed yet,
Why?
Please Help?
what causing the issue? Battery or Software or Hardware?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Battery issue? It could be your battery doesn’t work.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Yes, as your answer, I replaced new battery Then WOW, it worked perfectly, Thank you so much :D
tarafından
Yorum Ekle
Yanıtını ekle
Sam Festus sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 68
