Ana içeriğe geç
The Motorola Droid (model number: A855) is a full keyboard touchscreen smartphone powered by Android.
How would you fix a broken or non-responsive power button?
A couple of months ago the power button on my OG Droid stopped working. It is flush with the top of the phone, doesn't press down any more, doesn't spring back up, nothing. Would anyone be able to do a write-up or guide on how to fix it and what to use to fix it? Something on how to repair it to its original functionality. I read that the foam under the button eroded and could be replaced by using the rubber from earbud cushions. It wouldn't be a problem for me to do, but it would make it easier for me after looking at it already done by someone else. Any and all help is appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
5 Cevap
Filtre ölçütü:
Bu cevap aslında başka bir soru için verilmişti.
Depends on what's causing the malfunction. If the button is just not registering because it's not being fully pressed anymore filing away a bit of the case or cleaning any debris from underneath the button may fix it. If it's an electrical issue it might be much harder to track down.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
The round copper contact under the button that flexes and connects two wires on a ribbon has fallen off the ribbon. they are $13 for the tiny item online(google). you will need a t5 tork to open the back cover. you will also have to peel the speaker, camara, and antenna covers off to get to the screws. they are $5 each to replace and the sticky will not save. search youtube for a video show exact steps to open. Best left for someone with experience working on phones.
Puan 0
Yorum Ekle
Anyone know the name of the part, to fix the power button issue? Does Ifixit.com have it in stock?
Thanks!
Puan 0
Yorum Ekle
I replaced one of these monday and it was not that bad. I ordered a new flex and used a heat gun to soften the glue on the flex so it could easily be removed and reinstalled. Be careful with the vibrator part of the flex it can be damaged easily. Take your time and install just like it came off and you will have no problem. This is a pretty easy phone to work on. I did not need to purchase any extra parts to complete the repair. I used double sided tape to replace any tape that did not restick. If you use heat to remove the covers the tape should come off with no problem.
Puan 0
Yorum Ekle
Where do you get the new flex?
Puan 0
Yorum Ekle
Yanıtını ekle
Jay sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 7,250
