Ana içeriğe geç
Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Can I remove logicboard and put it into A1599 housing? (IPAD mini 3)
Hey guys,
I’ve got a scenario here.
If I take the logicboard of an Ipad Mini 3 (Model A1600; wifi + Cellular), would it work if put it into the housing the IPAD mini 3 (Model A1599; just wifi) ?
I just want check if this is doable.
Thanks
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This isn’t something I have tried myself but I suspect it would. The iPad mini logic boards aren’t screwed into the housing like iPhones are so you don’t have to worry about proper placement of screw holes. The main difference between the two versions of logic board is that the WiFi only board has a large hole where the RF infrastructure would be. All of the other flexes are universal.
So if you already have the two boards, I would certainly give it a try.
Replace a logic board (motherboard) compatible with the 3rd Generation iPad mini Wi-Fi model. Fix processing issues like unexpected shutdowns, reboots or water damage. Görseli
Ürün
iPad mini 3 (Wi-Fi) Logic Board
$69.99
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Ckalable upflow sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 23
Her zaman: 452
