Ana içeriğe geç
The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
SD Memory Card maximum
What is the maximum size SD memory card the Canon PowerShot A580 IS will accept?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
According to the User Manual your camera accepts SD memory card/SDHC memory card/MMC Card/MMCplus card/HC MMC plus card. This means you could probably use a 32GB card. I do believe that most people do not go higher than 8GB to prevent read/write errors and buffer overflow etc.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
My 590 is keeps saying memory card error and won't do anythinng what is the problem?
tarafından
Hi brianshackelford607,
Have you tried a different SD Card?
Try using a card reader connected to a PC to verify if your SD Card is still OK or if there is a problem with the camera
tarafından
Yorum Ekle
Yanıtını ekle
good2go7 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 4,256
