Ana içeriğe geç
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
427 Soru Tümünü görüntüle
broke the "small antenna" during battery change procedure
During the battery change procedure, which went well for the most part, I broke the “small antenna cable” identified in section 17. Didn’t notice until reassembly. Since it is not the GPS nor the WI-FI antenna, I’m unclear exactly what I will find inoperative once I finish. Is a replacement available? (I was confused by the difference in picture between the Wi-Fi model and mine. Oh well.)
Bu iyi bir soru mu?
Puan 0
2 Yorum
I’ve never used the Cellular capabilities of the mini 2, so will I miss anything if I do nothing? Will the mini constantly remind me that the antenna is broken? Note: I bought the cellular version to get the improved GPS capabilities.
I’m off now to get some 90% isopropyl to clean the gunk left behind from the glue.
tarafından
I don't believe so.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It is the Right Cellular Antenna. With a damaged antenna, you will have less (or no) cellular sugnal.
iPad mini & mini 2 Right Cellular Antenna Görseli
Ürün
$9.99
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Leon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 76
