Not sure which kit to buy
I have a MacBook Air 13" Mid 2011 and the charge doesn't charge anymore and now I decided to fix it. I think I should replace the battery and the charger connector. Could someone help me to choose?
Bu iyi bir soru mu?
Puan
0
So at this point what is the MagSafe connectors LED telling you? Is it Amber, Green or not lit at all?
Looking at the MagSafe cable is it worn or damaged in any way?
Looking at your systems MagSafe port is all the contacts the same color is there any dirt around them?
If your system is running, let's get a better idea on your battery. Install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
Dan tarafından
Hi Dan, thanks. The magsafe is out, sometimes it goes green but never orange as it used to when was charging. The system is down, there's no way of installing an app.
Guilherme Borges tarafından
@guimarques - Hows the MagSafe cable and the connector?
You may need to replace one or both. And we still don't know if the battery its self is still good.
Dan tarafından
