Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2376 Soru Tümünü görüntüle
How can you recover data from a completely dead iPhone 4?
I have an iPhone 4 (or 4s don’t remember) that I used to use back when I was a teenager years ago.
I have lots of messages and photos that I’d love to see again, but I’m pretty sure the phone was water damaged. It’s never turned on either when plugged into a pc or charger.
Phone is completely lifeless.
Is there a way to recover all its data? Like, can I buy a working iPhone 4 and swap its motherboard or something?
Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
You mentioned that it may be water damaged, therefore to confirm this you should follow an ifixit guide to open up the rear cover and check the water stickers (red means water has got in, white means it is fine however these stickers are hyper sensitive and get red even with a bit of water vapour), if you have any tools to check the electrical flow on the motherboard after putting in a charger it would help, and later you may need to desolder the flash storage chip. Unfortunately these are simply my knowledge and I am not certified to do this kind of soldering work, so i am only able to help you up to here. I wish you good luck in getting your memories back.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
The storage is unfortunately on the motherboard, so replacing it would just give you the data of the iPhone that board came from.
Puan 0
Yorum Ekle
Recovering the data required making the phone usable again, replacing a few individual chips that controlled functions like USB, touchscreen, and the display.
Puan 0
Yorum Ekle
Yanıtını ekle
Truzzie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 84
