Ana içeriğe geç
The April 2014 update of the 11" MacBook Air packs refreshed dual-core i5 and i7 Haswell processors and slightly increased battery performance.
100 Soru Tümünü görüntüle
Won´t sleep when close lid, faulty hall effect sensor?
The MacBook running newest MacOS Catalina won´t sleep when i close the screen/lid.
Tried reseting SMC and PRAM, also tried running a magnet along all edges with no effect. Running on original Apple SSD.
Wondering where the hall effect sensor is located on this model? Is it part of the I/O board as I’m suspecting this is faulty and needs replacing?
Could re-installing MacOS Catalina help? If I manually enter sleep and close the lid it´ll sometimes react once closed and wake up, this is the only scenario in which I seemingly am able to get a reaction from the lid sensor.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Apple loves moving things about! This series Hall sensor is located on the main logic board on the back side as you can see here:
Pop the logic board out and inspect it for corrosion MacBook Air 11" Early 2014 Logic Board Replacement if you see anything take a nice sharp picture and post it here for us to see Adding images to an existing question
iFixit Görseli
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
MacBook Air 11" Early 2014 Logic Board Görseli
Kılavuz
Zorluk:
Zor
30 minutes - 1 hour
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks for the picture. I’ve found the problem and it’s the transistor(?) that seems to have snapped/fallen off at some point. Can the individual transistor can be bought from somewhere? If not guess i´ll have to find a donor from a model that has the hall sensor on it’s IO board as I´m guessing it’s the same transistor type on different year models.
tarafından
@wackster - Apple hasn't altered the design over the years so I do think you can salvage the Hall sensor from another board.
tarafından
Yorum Ekle
Yanıtını ekle
Marik sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 245
