Is there a way to run this machine with no display?
4-5 weeks after replacing the internal HD on my daughter’s late-2013 27” iMac, the display just…fell out. I don’t know if the adhesive was faulty, or I just didn’t apply enough pressure. (I genuinely thought I had.) But it is what it is. ¯\_(ツ)_/¯
When the display fell out, it damaged the LCD data port on the logic board, which I discovered after having ordered a replacement display. The iMac will still boot and work with an external display, but without sensor data from the LCD, it’s throttling the CPU to 20%. I’ve calmed the fans with Macs Fan Control and removed the IOPlatformPluginFamily.kext from System/Library/Extensions, but the CPU is still being throttled.
Is there any way to get this machine back to a semi-useful state (it has a Nvidia GPU, so I can use it for Iray), or is it just scrap at this point? Any suggestions would be greatly appreciated! Thanks!
Bu iyi bir soru mu?
Can you post some pics so we can see the damage Adding images to an existing question
Dan tarafından
