Ana içeriğe geç
OnePlus 7, OnePlus tarafından üretilen bir Android akıllı telefondur. Mayıs 2019'da duyurulmuştur.
battrey one plus 7
هل بطارية OnePlus 6T متوافقة مع OnePlus 7
Google Translate
Is the OnePlus 6T battery compatible with OnePlus 7?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
They are different batteries and they are not interchangeable.
For a OnePlus 7 it is a BLP699 (4000mAH) and a OnePlus 6T it is a BLP685 (3700mAH).
Also when looking at images of the two batteries, (see below) the flex cable connections are located in different spots so a 6T battery won’t line up with the systemboard connector in a OnePlus 7
Resim
(click on image to enlarge for better viewing)
Google Translate:
مرحبا، إنها بطاريات مختلفة وليست قابلة للتبديل. بالنسبة إلى OnePlus 7 ، فهو BLP699 (4000 مللي أمبير) و OnePlus 6T هو BLP685 (3700 مللي أمبير). أيضًا عند النظر إلى صور البطاريتين ، (انظر أدناه) توجد توصيلات الكابلات المرنة في أماكن مختلفة بحيث لا تتوافق بطارية 6T مع موصل لوحة النظام في OnePlus 7
(انقر على الصورة لتكبيرها لمشاهدة أفضل)
marhabaan, 'iinaha bitariat mukhtalifat walaysat qabilat liltabdil. balnsbt 'iilaa OnePlus 7 , fahu BLP699 (4000 milli 'ambira) w OnePlus 6T hu BLP685 (3700 milli 'ambir). aydana eind alnazar 'iilaa sur albitariatayn , (anzura 'adnah) tujad tawsilat alkabilat almarinat fi 'amakin mukhtalifat bihayth la tatawafaq battariat 6T mae mawsal lawhat alnizam fi OnePlus 7
(anaqir ealaa alsuwrat litakbiriha limushahadat afdl)
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks for your reply, but I think there's some confusion between the OnePlus 6T/7 battery and the OnePlus 7 Pro battery.
The battery connector for the OnePlus 7 Pro is different, but the batteries for the OnePlus 6T and 7 are the same, with same connector.
tarafından Paylaş
@rfp49293
According to the manufacturer, they use different batteries for the 6T and the 7.
They have different model numbers and capacities i.e. 6T = 3700mAH, 7 = 4000mAH.
Also looking at images of each battery the battery cable is in a different place. 6T battery - BLP685, 7, 7 Pro battery - BLP699
Here's the battery information for a OnePlus 7 Pro and Pro 7 5G for those who might want it.
Phone Model #GM1910, GM1911, GM1913, GM1915, GM1917 Battery model # BLP699 capacity 4000mAh, p/n 1031100009
Phone model #GM1925 Battery model # BLP699 capacity 4000mAh, p/n 1031100009
The 7, 7 Pro and 7Pro 5G all use the same one i.e. BLP699 battery
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
sssvvvyt sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 59
Her zaman: 1,207
