Ana içeriğe geç
Audio Works But No Picture
Title says it all. When turning the tv on, the audio works but video does not. Have tried unplugging and plugging hdmi cable, swapping out for a different hdmi cable, and have tried unplugging and plugging the coaxial for the cable box, nothing works.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Hi @tamrielbound ,
Can you view the TV menu screens OK?
Have you tried a different signal source, e.g. a dvd player and checked that it works OK when using it?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @tamrielbound ,
Can you view the TV menu screens OK, you didn’t say?
If you can’t see an image when trying either of the above, with the TV on and audio heard, shine a torch at an angle close to the screen and check for any images. They will be very faint if they are there so trying this in a darkened room may help to see them if they are there.
If you can see images then there is a backlight problem with the TV
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I can not see any images such as the menu screens. I tried several different hdmi cords, I tried a DVD player and a blu ray player. The backlight is working, you can see it go on and off with the tv. The backlight also flashes when I hit the Netflix button on the remote.
tarafından
Yorum Ekle
Describe tv model and to where you are connecting the cables.
Puan 0
2 Yorum:
TV is the LG 43UK6300PUE and the hdmi cable is connected from the cable box to the tv.
tarafından
And the cable box, is it connected to the dish? Then, you call the cable provider to set it at your place.
tarafından
Yorum Ekle
LG sets made in 2018-2019 with BOE panels (including but not limited to European markets) are at a high risk of developing a fault with the screen panel/LCD module. The screen appears black, but the backlight behind is on - the 'OFF' state of LCD screens is black (blocks the backlight).
Mainboards of these sets have two versions: ones with two wider #1 and #2 LVDS connectors (68 pins each, for BOE panels) or two a little shorter LVDS connectors (60 pins, for LGD panels).
Puan 0
Yorum Ekle
Yanıtını ekle
Charles Jackson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 230
