iPhone 11 pro not included
Hello, the phone is obviously dropped and does not turn on. what is its problem circuit board or battery.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If you did have vibrate on mute enabled, you can perform a quick and easy test. Simply flip the mute switch. If it vibrates then its obviously not the battery because it is powered on. You could also try to call your number. If it rings then again, it’s powered on. If you dropped it you most likely damaged the OLED panel.
Bu yanıt yardımcı oldu mu?
Thanks for the info will work. ;)
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 261
2 Yorum
have you tried a replacement screen at all?
Jade Richards tarafından
I'm not I thought it was the battery
dimit1r89 tarafından
