Ana içeriğe geç
KitchenAid Artisan Serisi 5 Quart (4,7 Litre) Tilt-Head (Yatan Başlıklı) Stand Mikser, model numarası KSM150PSER. KSM150PS ile başlayan tüm modeller aynı cihazdır, yalnızca renkleri farklıdır.
Wire whisk stuck on
The wire whisk is stuck on the rotator shaft. I’ve turned it up and to the left but it’s not coming off. Also not sure if the rotator should be moving but it does in its planetary way while trying to remove it.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If the planetary is moving something has probably failed inside the gearing mechanism. You should be able to grip the drive shaft with needle nose pliers and remove the whisk easily. Keep in mind that it has to slide upwards slightly to disengage from the “bayonet pin” on the drive shaft though. Make sure you unplug at outlet before attempting!
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thank you. I think i need to return it then as its only a week old and the rotary keeps moving as I try and remove it. thank you.
tarafından
Actually, I had put some vegetable oil on it with a tip and still couldn't get it off but I managed to do it with the pliers so maybe i don't need to send it back....thank you.
tarafından
Yorum Ekle
Yanıtını ekle
wendy macdonald sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 546
