Ana içeriğe geç
26 Ekim 2018'de piyasaya sürüldü. A1984,A2105,A2106,A2108 Modelleri ile bilinir. GSM veya CDMA/eSIM , nano-SIM veya dual-SIM / 64, 128, veya 256 GB / Siyah, Beyaz, Mavi, Sarı, Mercan veya Kırmızı. ("iPhone 10 R." olarak telaffuz edilir.)
468 Soru Tümünü görüntüle
iPhone XR Back Glass Replacement
So I’m just about to replace the back glass on an iPhone XR that I bought. I’ve seen a couple of people gutting the phone completely and some people leaving the unit intact. I have no problem taking the entire phone apart as I’m quite experienced with mobile repairs. I’m using a combination of heat and IPA to take off the glass. My question is, is it necessary to gut the entire phone for this repair? I can understand taking out the battery but what about all the other components?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Personally, I just remove everything to be safe due to all the plastic around Loud speaker, Port, buttons have rubber gaskets, etc… but main thing is the flash module on Power button flex… it tends to float/bridge easily due to low melt solder. for an extra few minutes of prep, it makes it worth while after reassembly, eliminating the troubleshooting of any issues
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Much appreciated, thank you for your response!
tarafından
Yorum Ekle
En Yararlı Yanıt
hello Luke,
everything is depending to your method. Some people use a 400-500 degree C, so I thing that’s necessary.
  • regards,
Puan 2
Yorum Ekle
Yanıtını ekle
Luke sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 1,497
