Wifi antenna snapped off during mobo repair
Final Edit:
Although the tips i got here were exactly what i needed, i didnt manage to repare the MBP this way. It was nearly impossible to remove the ring that was stuck to the antenna and there were few repair shops with the equipment i needed to repair this.
Additionally, this laptop was not mine, but from my boss. She will give this laptop (which had other damage that i repaired) to her daughter, who will enjoy it a lot, but will have to use a USB WIFI dongle.
Thank you for all your tips!
Original post:
During the teardown of this macbook pro i snapped of one of the 2 wifi antenna connectors on the logicboard. (Red is still working, blue snapped off, i color coded the mini cable with its corresponding place on the logic board) (see attached photo)
‘front’ view of the cable. There is still a piece ‘inside’ the mini cable that should normally be on the motherboard
how the motherboard is looking right now
side view, but unfortunately its very hard to capture that there is something still attached to the mini cable
I can get replacement HMF4 antenna cables, but since i snapped of the part with which it connects to the mobo, i dont feel this will accomplish anything.
Since the connector is still visible, i feel like this should be an easy fix, but is it possible to repair this? Should remove the pin from the antenna cable and resolder it back on? or is this device with this mobo now doomed and should i get a dongle for wifi?
Please let me know your thoughts. I am especially curious as to what data lines you think are going into the board (is it just the piece in the middle that is connected to the mobo, or are there connections aside from the pin in the middle that will also need to stay connected to the mobo?)
Weirdly enough, i can still connect to my wifi (when i leave both unplugged) but i cant load web pages.
If anything is unclear, please let me know!
Simon
Bu iyi bir soru mu?
4 Yorum
Simon can you post the picture/s please. Here's the guide Adding images to an existing question
DanJ tarafından
@danj Oops, even prepared a good photo, but forgot to add. Let me know if this picture is sufficient, or if you need any other angles of the logic board
Simon tarafından
@Simon Grootendorst - Can you take a few more nice and sharp closeup of the logic board straight down so I can see the solder pads and the matting surface of the logic board connector which is still stuck on the cable connector end. Do't damage it!
Hint: Have someone hold a set of LED flashlights to light up the area
DanJ tarafından
I added some pictures, which are the closest i can make without my camera unfocussing.. I hope the question is clearer now, but you can now clearly see that there is a piece missing where the blue arrow is indicating on the motherboard. This piece is now inside the mini cable. Is it possible to solder this back onto the logicboard?
Thank you for your time and suggestions! Please let me know if there is something else i can try to do to help you help me :)
Simon tarafından
