Ana içeriğe geç
Why are there horizontal lines on my screen?
I have had this laptop for a year now, and this problem only recently started to occur. Whenever I open my laptop and do anything, I would see a bunch of colorful horizontal lines on my screen. I went to device manager and it said my NVIDIA GeForce RTX 2060 has stopped working because of a problem. What exactly is wrong with my laptop?
Bu iyi bir soru mu?
Puan 0
3 Yorum
Hi Anthony,
I have the same problem with small lines in the bottom in my Legion 5 , did you find what was wrong?
tarafından
I've a legion 5 with RTX 2060 and having the same problem on the top of the screen, how are your laptops going so far?
tarafından
Same here, legion 5 with RTX 2060 and black horizontal lines at the bottom of the screen
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Have you checked that the latest video drivers are installed?
If you cannot get Device Manager to show that the Nvidia adapter is installed OK by uninstalling/reinstalling drivers etc, then it may be a GPU problem on the motherboard and possibly also a display problem as well
If you can get Device Manager to show that the video adapters are both installed OK and the display still has lines then try connecting an external monitor to the laptop and check if its display is OK. Check using both adapters, Intel and Nvidia.
If the external monitor also shows lines etc then it is a motherboard problem.
If the external display is OK then it may be a faulty EDP video cable or cable connection (at either end, motherboard or panel) or a faulty panel.
Here’s the hardware maintenance manual for the laptop that will help you to check the EDP cable connections and to remove / replace the LCD panel if necessary.
If it appears to be a faulty panel, here’s a link to the parts list.
Type Legion Y540-15IRH Laptop (Lenovo) in the “Search by product name etc search box”, select your exact model variant that shows up and then click on Select Commodity > LCD panels to find the part number (FRU) for the panel. Once you have the part number search online using the part number only to find suppliers. usually the part number is printed on the back of the panel somewhere if you wish to verify that you have the correct one.
Hopefully this will help you to find and fix the problem
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Anthony Wong sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 13
Son 30 gün: 66
Her zaman: 5,990
