Ana içeriğe geç
The Asus Tuf Gaming FX505GT Is A 15.6 Inch Laptop With A Intel Core i5 9300H And A GeForce GTX 1650. It has Windows 10 and was made by Asus in 2018.
Not connecting to monitor
Hi .. can someone help lol
I normally connect my laptop to the TV via HDMI and a few weeks back after an update , it stopped doing that and would only do it through a wireless connection … I then got a samsung monitor for use with my xbox and I tried to connect laptop to that using HDMI (monitor does have DVI port) and it still isnt having it but in the settings , the monitor is listed so the laptop is recognising it somewhere … Any ideas without taking laptop back before the update that ASUS have advised me to do … ? Thanks
Bu iyi bir soru mu?
Puan 0
2 Yorum
Have you tried using different cables? I would also double check for NVidia driver updates for your graphics card. It's plausible that the update caused some OS corruption, or exacerbated existing corruption, but that is a more complex fix if that's the case.
tarafından
Thanks for your reply ... I have tried different cables .. apart from the DVI cable as I havent got one .. just ordered one so will try that then I will have a look at the graphics updates and I dont even wanna think about corruption haha !
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
@listersister12
Hi Jen,
An update of what? A driver? Just roll it back with Device Manager, if a driver. It worked before the drive update so that is the most probable cause. That should fix it.
It is unlikely, but not impossible, that it is the cable, especially if it worked before.
I guess you have checked that the Samsung was set to the correct input?
Still not working? Corruption is no big problem so you can think about it. First just uninstall the Graphics driver, reboot and then let Windows rediscover it. If you really think there is still a prfoblem then use Display Driver Uninstaller or DDU:
https://www.majorgeeks.com/files/details...
which completely removes all traces of the driver. Re-install.
Let us know how it goes.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Hi Mike ...
The update was a few things .. I just set them going from the windows update page on the control settings .. I didnt actually take much notice of what was being updated to be honest - it was one of those days and I just set it away doing its own thing without actually taking much notice !
Defo not the cable as I have tried so many and monitor is still not picking up laptop and yeah the monitor is in correct input ...
I will have a look at the device manager thing now and if that doesnt do it I will do the display driver uninstaller and go from there ..
Thank you for your reply
tarafından
Yorum Ekle
Maybe graphic card has an application to config external monitor. Have you checked it?
Puan 0
Yorum Ekle
Yanıtını ekle
Jen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 3,723
