Ana içeriğe geç
The Wii U is a video game console paired with a handheld device made by Nintendo that allows users to play games on the GamePad. Repairing the console is straightforward as the device is very modular.
189 Soru Tümünü görüntüle
Why is my Wii U Gamepad not charging?
Hello, I just recently got my Wii U gamepad out of my closet after about 3 Years of no use, It was in a box so there wasn’t much dust except for in the Wii Remote Battery Cases, The Wii U gamepad was doing just fine and charging well, but then when the Gamepad Died about a month ago, it wouldn’t charge, no light was showing, and I was extremely angry because the Wii U houses some of my greatest Nostalgia of gaming from back in 2013, please help, thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Did you check the battery? Most often, after years of little or no use, it will lose its ability to hold a charge. So, I would start there.
If you have a way to check the charge on the battery, that will help to see if it is dead. Although batteries are relatively inexpensive and easy to find, so if you don’t have any testing equipment, just try a new battery.
If that is not the issue, there are fuses that are related to the charging system that are put in place to stop a power surge from destroying your gamepad. It could be that one of them is blown. They are extremely small and it would require someone that can micro-solder to replace it. I wouldn’t recommend putting a solder blob in its place, although that may sound like an easy solution, it will not protect the circuit, which is why they are there to begin with. Look for the F1 and F2 fuses on the motherboard, but be careful not to poke around them too much, like I said, they are very tiny and easy to knock off the board. If one or both are bad, have them replaced.
Hope that helps.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Juan Vela sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 63
Her zaman: 2,379
