Battery Level dropping from 60% to 7% instantly
Hi!
This is the second time I’ve replaced my battery with an ifixit battery and this is the second time this issue has came up. After replacing the battery and running the calibration cycle, I would use my laptop on its battery and somewhere around 70%-60% battery level, the battery level would just shoot down to 7%.
Initially on the first time around with replacing the battery, I just figured they sent me a faulty battery, but didn’t have time to buy another one and change it out, so i lived with the power adapter. I finally had a chance to replace it to a new battery, but the same thing just happened. Now, Im hoping to find some answers from you all if I have another faulty battery or some other insight on what it might can be.
Appreciate whatever insight provided!
UPDATE
Here’s a photo with the coconut battery app. In the screenshot under the “BATTERY (last 12 hours)” you can see the instant drop in battery level.
UPDATE #2
at 50% charge
at 100% charge
UPDATE #3
Screenshot charging from 0% to 50%
Bu iyi bir soru mu?
9 Yorum
was the charger connected when you took the snapshot? What was the color of the MagSafe charger LED Amber, Green or not lit?
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
Dan tarafından
@danj The charger was not connected when the snapshot was taken. Though when I initially charged the battery, it seemed to work as aspected. Amber when charging and Green when fully charged
Rodney tarafından
@rodneyd - Lets see what CoconutBattery shows. I'm not sure if you really have a problem with the battery or just hadn't allowed SMC to meter out the battery so it learned what the min-max levels of the new battery.
Dan tarafından
I've seen this exact problem happen on the same model machine after replacing the battery (it would even jump specifically to 7% charge). I never learned exactly what was causing the issue and chalked it up to a battery calibration issue. I replaced the battery again and calibrated it by letting it fully charge, then fully discharge, then fully charge again. I couldn't recreate the problem afterward, but I only tested for about 24 hours. I'm beginning to think there might be an issue with this model that causes this to happen after some weird event occurs. Good luck!
Zach tarafından
@danj I've updated the post showing what CoconutBattery shows after the battery level has dropped. I can also update it again to show what CoconutBattery reads when the laptop is plugged in and fully charged if it will help you give a better assessment. Thanks!
Rodney tarafından
4 tane daha yorum göster
