Need a new wireless card
Hi - I need a new wireless card for a 13” MacBook Pro (Late 2013). Was having trouble finding the right device on this site, any help is appreciated.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Here’s the needed part MacBook Pro 13" and 15" Retina (Late 2013-Mid 2014) Airport/Bluetooth Board and here’s the guide to put it in MacBook Pro 13" Retina Display Late 2013 AirPort Board Replacement
But before you swap out the AirPort board how about telling us what your issue is you may have a very different issue either a software issue or the antenna unit.
Bu yanıt yardımcı oldu mu?
It seems like other issues I've had with Network HW before. The wireless will connect, but it won't maintain the connection - the "searching for wireless networks" message is seen on a regular basis, but it won't stay connected to the wifi
Let's see if we can diagnose the issue as it could be your antennas cable which is damaged and/or the Access Points (AP) settings are messed up in your system.
Go into your WiFi settings and delete all of your networks (make sure you write down the AP names and passwords as needed first) Then add in the one thats you are currently near.
Did that fix things? If not pop off the bottom cover and take a picture of the WiFi cables at the AirPort board as well as where the cabled enter into the hinge and post them here for us to see Adding images to an existing question
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 42
