How can I fix memory up to 1tb
I want to fix my laptop memory and keyboard
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi
Here’s the hardware maintenance manual for a Lenovo Ideapad 110-15IBR laptop.
Go to p.40 to view the necessary pre-requisite steps and then the procedure to remove the HDD (hard disk drive) so that it can be replaced with a 1TB SSD (solid state drive)
Here’s a link to just one supplier of SSD for the laptop. It is only to show what is compatible with the laptop and how much it may cost. A 1TB SSD is listed by the supplier.
There are other suppliers online that may suit you better. If you get one somewhere else ensure that you also get the 9.5mm adapter as well so that the 7.0mm SSD will mount properly in the laptop.
If you’re having problems with the keyboard, that have been proven to be in the keyboard itself i.e. by using a USB keyboard attached to the laptop and having no problems when using it, then usually it is easier to replace the keyboard than to try and fix it as you can cause more problems that what you originally had when trying to fix keyboards.
The keyboard is part of the upper case assembly. Go to p.51 in the manual to view the necessary pre-requisite steps and then the procedure to remove the upper case assembly. On p.65-66 Item #2 you will find the part numbers for all the country specific keyboards for the model (make sure that you look in the Ideapad 110-15IBR model column).
Once you have found the part number applicable to your particular model, search online using the part number only to find suppliers of the part.
If you wish to verify that you are ordering the correct part, usually the part number can be found printed somewhere on the underside of the upper case assembly in your laptop.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 4
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 118
