Ana içeriğe geç
Second generation of the Fairphone, made by the social enterprise with the same name. Released in December 2015. Model number: FP2-XCVR
20 Soru Tümünü görüntüle
I need to put my speaker on when calling
I have a Fairphone 2. it still works quite okay, I only have the issue that the one receiving my phone call doesn’t hear my voice unless I put the speaker on which means that I don’t have any privacy anymore as everything we talk about is loud and clear for everybody :(. What do I have to replace in order to solve that problem?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
First use a strong light and a magnifying glass and check if you can see if the voice inlet hole on the bottom edge of the phone appears to be blocked at all. If it is or if you’re not quite sure, do not use a pin or probe to try and clear it as you may damage components in the phone. Try using a vacuum cleaner to suck out any obstruction.
If you still cannot be heard on a call, most probably there is a problem with the primary microphone
Here is a link to the ifixit Fairphone 2 Microphone Module Replacement guide that will help.
There is also an app available on the phone that allows you to test the primary microphone as well as a lot of the other hardware in the phone which may also help.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Rina Teeuwen-van der Ende sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 242
