Ana içeriğe geç
Repair guides and support for battery-powered toothbrushes.
Repairing Electric Toothbrush Charger?
Hi guys,
The chargers of my Braun electric toothbrushes fail every few years so I end up buying another. I have 4 working toothbrushes but only 1 working charger.
There are plenty of guides for the actual toothbrushes on ifixit but none for the chargers. Just wondering if there’s something simple I could check on a faulty charger?
The charger looks like this:
Oral-B White Pro 1000
Thanks
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
The charger uses wireless charging to charge the battery in the toothbrush. The same principle is used with some mobile phones (Qi charging).
If you have a multimeter, coil some wire and put it where the toothbrush sits on the working charger. You should be able to measure an a.c. current across the coil. It should make a compass twitch too, maybe even a paperclip.
Given that the charger plugs directly into the AC mains power supply there most probably is a fuse in the charger so this may be the first thing to check.
The hard part in trying to repair the charger is access without any or very little damage to the case or the components inside.
Looking at images of the charger it appears that it is in a molded plastic case with no apparent seams. No doubt this it to make it as waterproof as possible given that a wet toothbrush could be placed on it.
If there is a seam on the case, try placing a sharp wide bladed tool e.g. a sharpened 1 1/2” paint scraper, along the seam and give it a short sharp tap with a hammer. Usually this will break a plastic welded case along the seam line with minimal damage
If there is no seam then you would need to somehow cut open the case, without damaging the internal components and then start checking the circuit board components inside.
If you could do this without too much damage then it may be possible to repair them but they would then need to be resealed and made waterproof again to be able to use them again in the usual place.
If you still have all or most of the old non working chargers then perhaps you could try and experiment to see how difficult it is and what the actual problem with them is.
If you decide that you might try doing this create a guide while you’re doing it. Others in the future will thank you. Here’s how to do it on ifixit Creating a Repair Guide
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
En Yararlı Yanıt
I managed to crack open the bottom of a 3757 charger with a knife and a hammer, I would consider them as non repairable as they are filled up with some plastic resin.
Puan 4
5 Yorum:
How do I open tooth brush to change battery?
tarafından
Thanks @cmymail, you've saved me the effort. Poor form by Braun. They've been using the same charger design for at least a decade. Non repairable products are a blight on our world and should be banned. Braun, it's past time to make a change.
tarafından
I agree. Back to a manual tooth brush.
tarafından
It really makes me angry that I and others will put piles of these unrepairable products in our local landfills.
tarafından
Yorum Ekle
Yanıtını ekle
Stephen Shaw sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 17
Son 30 gün: 85
Her zaman: 14,497
