Ana içeriğe geç
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 Soru Tümünü görüntüle
Soru Kapandı
How does the 3DS Pedometer work?
In debating with someone I have come to ask how does the 3DS measure steps? is the pedometer based of the accelerometer or is there an actual pedometer device built into the 3DS?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Pedometers (typically) work 1 of 2 ways:
piezo-electric accelerometers
Mechanical Pendulum System
Being that the 3DS has accelerometers in it already, my guess would be that that is how the pedometer works.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
The 3DS seems using the mechanical. You can hear the clicking sound if you shake it.
Puan 0
3 Yorum:
That is the stylus and Circle Pad moving around.
tarafından
its not the stylus and circlepad moving around. try it yourself. (remove the stylus, hold the circlepad)
tarafından
It is also the buttons moving around. Also, there would be no room for a mechanical pedometer. If you look at the teardown you will see that there is mechanical no mechanical connections in the device.
tarafından
Yorum Ekle
The problem with the pedometer being a rail type is it'd not in the photos I'm pretty sure it's not a rail pedometer. There seems to be other pieces behind the circle pad that work in conjunction with the circle pad its self. It would make more sense that they would use the accelerometer instead spending more money and space on a rail type or ball type pedometer.
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,827
