Ana içeriğe geç
The XPS 13 9360 is a 13-inch laptop released in 2016 with a 7th-generation Intel processor inside. It was updated in 2017 with an 8th-generation processor.
How to remove broken headphone plug tip from headphone jack
Hi,
The tip of my headphone plug got broken and stuck deep in the headphone jack of my PC (dell xps 13 9360). Please i need ideas on how can I remove it. I checked online but i haven't seen helpful videos. Any suggestions?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @fooooe ,
Try opening the laptop and check if the broken tip can be pushed back out of the front of the headphones socket by pushing it from the back of the headphones socket. The headphones socket is mounted on the systemboard in the laptop
Be careful when working inside a laptop. Disconnect the battery from the systemboard (you don’t have to remove the battery, just disconnect it) as soon as it can be accessed once the laptop has been opened to minimize any potential electrical problems from occurring.
There is always power on the systemboard at various places even though the laptop is turned off. The power button is not a power isolating button. It’s function is to signal the BIOS/OS the intentions of the user. Think of the laptop as being in an extremely low power state when it is off rather than it is totally isolated from the power supply.
Also try not to touch anything that you shouldn’t and wear a wrist strap to help avoid any ESD damage if you do accidentally touch a sensitive component.
Here’s is the service manual for the laptop, taken from this webpage which should help.
You would only have to go as far as the removing the battery procedure as shown in the manual for access to the headphone socket to be available.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Thanks a lot! I'll try this out.
tarafından
Yorum Ekle
Yanıtını ekle
Fola Olu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 313
