You are probably going to need to Restore the iPhone Firmware. But first, connect the iPhone with Wall Charger for 20 minutes or so. It may restart itself and be fine, if so done. If nothing, then, keep on Wall Charger, and Reset, hold both Home and Power Buttons until the iPhone begins to restart. If it does and is fine then done. If nothing, with iTunes open connect iPhone to your computer. Hold both Home and Power Buttons until the iPhone is detected in Recovery Mode, usually takes about 20 seconds. Restore the Firmware with iTunes. If this does not work try DFU Mode Restore, with iTunes open and iPhone connected to computer, hold both Home and Power buttons for exactly 10 seconds, then release Power button, keep holding Home button until iTunes recognizes iPhone in Recovery Mode, about 10-20 seconds more time. If the iPhone screen is black, blank and iTunes says Recovery Mode, then this is actually DFU Mode. Restore the Firmware.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
53
when i try and turn my phone on it won't turn on so when i go to put my phone on charge it comes up with the apple logo and stays there for about 10 seconds then switches off and does the same thing over and over again, and I've just had the battery of my phone fixed about 1 month ago. I've tried to connect it to iTunes but it switches off by itself when its halfway through updating the software. i have no idea what to do. can anyone help with this without restoring my whole iphone. ?
its an iPhone 4s by the way
Heidi Mason tarafından
i need help because I'm literally about to throw it at something
If the phone doesn't boot up from the apple logo u will not be able to connect to I-tunes. I replace the battery in a friends Iphone 5c that did the same thing The new battery resolved the issue and costs $6-$8 bucks on e-bay.
Ted tarafından
well idk if i have the same probalem but when i turnt uit on it just shows apple logo for 3-4 seconds then turns right back off idk, maybe i jailbroke my phone
jadensiu tarafından
hai ask ta ko if whats your solution sa problem regarding sa apple na logo only but d na sya mo on,I have same issue man gud,thanks
amabaalecia tarafından
53 tane daha yorum göster
