Ana içeriğe geç
15.6", Intel HD Graphics, Core i3 2330M, Windows 7 Home Premium 64-bit, 4 GB RAM, 500 GB HDD
58 Soru Tümünü görüntüle
I have a problem with the processor fan working
When I turn on the device, I hear a violent sound of the fan that lasts for 4 seconds, with the device vibrating violently And also when I play or do a task on the device, knowing that I have cleaned the dirt.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi,
Here’s the service manual for the laptop.
Go to p.75 to view the necessary pre-requisite steps and then the procedure to remove the thermal cooling assembly. This will give you access to the fan so that you can check if it is OK (clogged with dust?) or if it is faulty and needs to be replaced.
If it is faulty then replacement fans are available online. Just search for Dell Inspiron N5110 fan or use the information from the label on the fan itself, to find suppliers that suit you.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Forg Eex sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 26
