MBA keeps shutting down due to temp even after heatsink and paste chan
I’ve got a 2012 MBA 13”
For over few months it started to randomly shut down - either while watching a stream, file transfer or using iMovie.
While using iMovie temps were rising to 100-103c all the time when exporting movie!
- I’ve started with changing the battery - old one was on it’s last stretch anyway. No improvement
- I’ve bought a new thermal paste (Arctic Silver 5) and applied it. Not much of a change
- I’ve installed software to monitor and tweak fans - this helped, but still using iMovie would raise temp to 100c with fans on max speed.
- 4) I’ve read about heatsinks that can leak… Mine was snapped on the leg behind the vent.
- I’ve replaced the heatsink with a used (not snapped) one and temps are basically the same as before!
My questions:
- Did “new” heatsink was also a leaked one?
- Is there any other reasons for CPU to overheat like that? Ventilator is working fine.
Update (01/23/2021)
Screenshots from TG Pro
Idle:
After few minutes of exporting video from iMovie (system fan settings):
Bu iyi bir soru mu?
How much RAM does your system have as well as the size of your SSD and how much of it is used?
I would recommend installing a good thermal monitoring App like TG Pro can to post a snapshot of the main window showing all of the sensors and the fan Adding images to an existing question
Dan tarafından
Hi Dan, It's a 4GB version with 128GB SSD. I've replaced SSD few years ago to OWC one.
I'll try TG Pro and keep you posted.
Eksajlee tarafından
@eksajleee - How much free space does your SSD have?
Dan tarafından
@danj 55gb free. I've updated my thread with screenshots from TG Pro. Thanks!
Eksajlee tarafından
