Ana içeriğe geç
2.6 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.2 GHz) with 3 MB shared L3 cache. Released February 13, 2013.
120 Soru Tümünü görüntüle
Battery decrease after replacing
I recently just replaced the battery. After only 7 charges the new battery is already at 97% capacity despite staring at 107%. Is this one just defective or what? I did calibrate it correctly as well.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
tarafından
@danj image added
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Well, the good news your issue is not the battery! Your charging logic on your logic board has failed! Often we find a knockoff charger burns the comparator logic so SMC can’t tell what’s going on so it just stops!
You’ll need to get your system to someone who can fix your logic board and a new charger, here’s the only source I trust Apple 60W MagSafe 2 Power Adapter (MacBook Pro with 13-inch Retina display) what is sold on Amazon or eBay are 95% knockoffs! Even when the seller says otherwise!
Here’s more on the affliction with knockoff chargers:
Bu yanıt yardımcı oldu mu?
Puan 0
7 Yorum:
Strange, for I am using an official Apple charger.
tarafından
@tyefr78 - Even I can't tell which is which visually! The only way I know of is using a good scale and weighing a known real unit and the one in question. The heaver unit was the real one.
tarafından
Oh, no this is one I bought from the Apple store.
tarafından
Then you must have gotten your system wet at some point as the SMC chip and the resistors it depends on to compare the level are near it and some what exposed to drips from the keyboard area.
tarafından
Ah, okay, thanks. Would you recommend bringing it in to a repair shop or am I besting a dead horse at this point?
tarafından
2 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Tyefr78 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 42
