Ana içeriğe geç
Asus tarafından üretilen 2012 yapımı Windows 8 işletim sistemli oyuncu dizüstü bilgisayarı.
shuts down at loading files
had this from new 8 years, always had the shut down after 10mins issue, but today turned on no worries, started playing a game it ran slow then crashed, now it will turn on but crashes before loading windows, tried going into safe to reload same problem crashes , is this fixable or do i move on
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
ok, got into bios, said connect power, hmm it was, checked, no green light on adapter, removed replugged it green light came on, connected to laptop,popped the main circuit breaker, and now adapter will not power up, i'm guessing this is my problem, at least i didn't pull the laptop apart looking for a problem that was not there
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi
If you have Win 10 installed, try getting into the Windows Recovery Environment menus to see if you can so a startup repair.
There are two methods to get there.
a). Start the laptop and when it boots into Windows press and hold the power button until the laptop shuts down. Do this 3 times in a row i.e. Start > boot > force shutdown > start > boot > force shutdown > start etc
On the 3rd attempt it should boot into the WRE menus.
If it does then go to Troubleshooting > Advanced > Startup repair and follow the prompts. Do not select Reset this PC because if you select the wrong option after this you can erase all your data as Windows will be reinstalled
b). If for whatever reason you can’t get into the WRE menus this way create a Win 10 recovery USB drive. To do this, all you need is access to any known working Win 10 computer, an empty 8GB USB flashdrive and 40-60 minutes of time.
In the host computer go to Control Panel > Recovery > create a recovery drive and follow the prompts.
When you have the USB recovery drive, start the laptop and get into BIOS (press F2) and enable the Legacy USB setting (or perhaps CSM) and also alter the boot priority to USB first boot option. Insert the USB into the USB port of the laptop, Save the changes and exit BIOS.
This will restart the laptop and it should boot into the WRE menus from the USB drive. See above for what to do once you’re in the WRE menus
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
gforsyth sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 329
