Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
Will not boot up after replacing the battery
Using the ifixit steps I replaced the battery and when the battery was fully charged I couldn’t get it to boot up so I could drain the battery. I went through the steps 2 more times to make sure that all connections were solid and still couldn’t get the computer to boot up.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
What is the color of the MagSafe charger LED? Amber or Green or not lit.
tarafından
It was Amber, then green when it fully charged after a few hours
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Double check your keyboard cable connection. Is the ribbon cable fully seated and squarely in? Did you properly flip the latch up to open and then close it to compress the cable? In the process of taking out the old battery did you nick the keyboard cable?
If your sure see if you can get the system to startup by using the Power Pads. Quickly short across the two square pads I’ve marked up here
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
The keyboard cable is secure and trying the power pads did nothing.
Is there a way to include pictures? I thought that might help.
tarafından
@j316 - Sure you can post images & short vids here's how Adding images to an existing question You can't do it in comments only in your Question or a new Answer.
Well this is not good :-{ If the Power Pads didn't start it then we have something deeper. It's not your battery
tarafından
Yorum Ekle
Yanıtını ekle
Jeanice Pratt sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 84
