Ana içeriğe geç
Lenovo tarafından üretilen 14 inçlik dizüstü iş bilgisayarı Lenovo ThinkPad T430 için rehberler ve onarım bilgileri.
Why is my second hdd not working?
i have linux and widows both on my notebook in dual boot.
when i boot linux it works fine with the hdd mounted. but when i boot windows it is stuck on the loading forever. when i launch windows without the hdd it works. i managed to get the hdd work but windows was much slower. when i try to format the hdd on linux i get input/output error. but when i connect the hdd trough usb everything works. is it a hardware problem? how can i repair this ?
edit: windows 10 pro and linux mint 20
Bu iyi bir soru mu?
Puan 0
5 Yorum
Many variables here, firstly does your linux distro boot without the second hdd? When you are able to boot windows, do you do it from grub?
tarafından
Hi @coconus ,
Is the latest BIOS version 2.82 installed?
tarafından
i am not sure. how can i check version of the BIOS ?
tarafından
Hi @coconus
When the laptop is first started and the Lenovo logo is on the screen press F1 to enter the BIOS setup menus. All the info should be there.
tarafından
BIOS version is 2.82
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @coconus ,
With the 2nd HDD connected, check that the 2nd HDD is not listed in the BIOS > Boot, boot priority list anywhere as it is a storage drive and shouldn’t be listed there.
If it is remove it from the list and then check if Windows works OK.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
it looks like it works. the windows runs fine now but i still get I/O error on linux(input output error). i will try to run the HDD on USB for some time to see if it wil work.
tarafından
Yorum Ekle
The OS using the HDD will absolutely be slower because USB is currently slower than SATA, M.2, NVMe, or any other current hard drive technology. Also, HDD drives are slower than SSD drives.
SSD drive may speed up your system and eliminate the I/O errors.
Puan 0
1 Yorum:
i have both OS on 120GB SSD split to two 60GB partitions in first slot for HDD
the HDD is 2TB and i want to use it as a drive for documents, videos...
the 2TB HDD is connected through the second slot for HDD the one where can be cd reader.
tarafından
Yorum Ekle
Yanıtını ekle
adam sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 27
Her zaman: 1,293
