Ana içeriğe geç
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
Getting a blank screen when I select system settings.
Just switched my 3ds on for this first time in a few years. Thought I'd check for a software update but when I select “system settings” I get a blank screen. I left it for a while but nothing happens. So I long pressed the power button to turn of and tried again. However the same think happend.
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Maybe a corrupt file
Bu yanıt yardımcı oldu mu?
Puan 1
8 Yorum:
Anyway of fixing or confirming this is the case?
Also I forgot to say, everything thing else is working fine. I can play games use the camera etc
tarafından
May be try this
The recovery mode (also known as Safe Mode Boot) can be accessed when turning on the Nintendo 3DS while holding A+R+L+Up(DPad). This menu is made to update your Nintendo 3DS through internet, if an update previously failed.
However it is possible to use this menu to delete the nagging update message if your console downloaded an update while in sleep mode. It is believed that this menu simply erases all update data, as it should normally be accessed when the update files are corrupted.
tarafından
That worked. Thank you so much. I had tried the safe mode previously but was using the stick as my up command.
Downloaded update and when it switched back on I could get to the system settings ok. Thanks :-)
tarafından
How do I open the safe mode? It keeps opening me camera even tho I use all the 4 buttons?
tarafından
@Fulcrum You have to turn off your 3DS and press the buttons while the 3DS is booting up.
tarafından
3 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Mogwai sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 1,303
