Ana içeriğe geç
Samsung's tenth-generation flagship "phablet," featuring its trademark S Pen stylus. Released August 2019.
20 Soru Tümünü görüntüle
Wont charge even after replacement parts
Hi,
this is for the s20 series along with the note 10 series (same issue ).
I have had multiple s20s and note 10s come in for not charging. wether they dont charge at all, or will still charge but show the yellow triangle, or just dont show any current at all.
I have replaced the charge port board, 2 flex cables along with the wireless charging /nfc part along with the battery and nfc pcb connectors. I have tried multiple parts from multiple suppliers multiple times with the same results, still wont charge. About 10% of these 2 models that come in one of those 4 parts fixes the issue and all is well. the other 90% are failed. I know there is the ic chip under the metal cover up and to the right of the battery connector however haven’t dug into that yet.
anybody else run into this?
thanks in advance!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
Hey,
I have a similar problem with my Galaxy Note 10 plus. It suddenly stopped charging via cable. Also no data transfers via cable.
So naturally I immediately cleaned the USB-C port. As this did not help, I replaced the daughter/ charging port board. Still nothing.
To be clear, if I stick a cable in the charging port the phone does nothing whatsoever. Luckily the phone can be charged wireless so that's what I´m currently relying on.
I´m not an electrical engineer so I´m kind of wondering what to try next.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
That happens ,you need to change the whole charging pad If the phone shows up with a temperature icon then that’s the issue
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
what charging pad is that?
tarafından
does the phone show a temperature icon inside the warning sign
tarafından
Yorum Ekle
Yanıtını ekle
Tyler sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 253
