Tape to wake dont work after screen replacement
After replacing the screen from a iPhone 11 Pro the function tap to wake dont work any more. i tried to put the function off and , and a soft reset but it stil dont work. The function lift to wake does works. Can it be a bad screen or is the phone damaged ? Its running iOS 14.4
Bu iyi bir soru mu?
Puan
0
did you replace the screen yourself or did you have a repair shop do it? If you did it yourself, where did you get the screen from?
Jesse Hooton tarafından
This is an issue I've seen a few times with the Tap to Wake function disabling after a screen replacement. Was the replacement part used an Original Apple screen, or a third-party aftermarket copy?
Liam tarafından
