Ana içeriğe geç
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 Soru Tümünü görüntüle
Horizontal lines on the screen after replacing the battery. Fixable?
I replaced the battery of my 2015 iPad Pro (A1652) following this video.
Everything is working great but the top 2cm of the screen are now broken and it’s only showing horizontal lines.
At first, not even the touchscreen was working but I fixed it by disconnecting and connecting it again.
That makes me think that maybe the lines on the screen could be a connection problem instead of a broken screen.
Can somebody with actual knowledge tell me if that is possible?
I was extra careful when I was detaching the screen (I even used a hair dryer) so I’m pretty sure that I did not break it… Although I’ll trust you if you tell me that I did haha.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You most likely damaged a component to the LCD assembly and you’ll need to replace the screen to fix it. Inspect the ribbon cables and connectors to make sure they’re not damaged.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Juanpi Briones sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 170
