Ana içeriğe geç
Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
327 Soru Tümünü görüntüle
Replacement battery from ifixit isn’t working
I installed my new replacement battery but it doesn’t seem to charge. The system report says that it recognises the battery but it shows that it doesn’t charge and needs servicing.
I opened up coconut battery and it also says that the battery itself is older than my macbook and that it is in poor condition. The battery is also charging with 0 watts.
I didn’t have any of these issues with my old battery which was actually still in good condition. Although it had a high cycle count the system didn’t say it needed replacing but I decided to do so anyway as the battery was discharging within 1.5 hours of use. Did I receive a defective battery from ifixit?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Check your battery board data cable connection and for any damage MacBook Pro 15" Touch Bar 2017 Battery Replacement Step 10
Bu yanıt yardımcı oldu mu?
Puan 1
8 Yorum:
Hi, that was one of the first things I did and it looks fine. None of the gold points are damaged. It might just be the case that the battery I’ve been sent is 5 years old and defective.
tarafından
@cooldude227 - Sure its possible! But the fact CoconutBattery is showing us the charger is connected just not charging, that's the charging logic within your system thats more likely suspect.
Are you using an Apple Charger and the cable that came with it? Apple did have a recall on the cable are you using the newer one?
tarafından
@danj Didn’t the recall only apply to the 2015/2016 version? I’m still using the original Apple cable that it came with. Also, my old battery didn’t have any issues with charging. The coconut battery app is showing that the new battery is in poor condition.
I’m going to reconnect the old battery and see if I have any luck tomorrow. Hopefully I didn’t damage the logic board or battery connector port.
tarafından
@cooldude227 - Think of it this way your car won't start what is the failure? Could be the lack of gas or it could be the fuel filter is clogged.
So you replace the fuel tank but the little bit of gas you had in the new tank is all you are seeing. So you assume the tank is bad. Not the fact the fuel filter is messed up.
Somehow we need to breakdown the problem so isolate what is failing.
tarafından
I've put my old battery back in and it works just fine, Im getting another replacement battery from ifixit soon so I'll test that out and see if I have any luck.
tarafından
3 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Cooldude2222 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 421
