Ana içeriğe geç
Breville Dual Boiler BES900 - BES900XL cihaz sayfası; onarım kılavuzlarını ve sorun giderme yardımlarını içerir. 2018 yılında piyasaya sürülmüştür.
How do I open the underside of the machine.
I’ve noticed ants coming in and out of a hole near where the water tray sits. I’ve been trying to get the bottom off the machine by removing every screw in sight, but the locking/unlocking wheel is the only thing stopping it from coming up. I can’t seem to take the wheel off, or loosen it up.
any help appreciated.
thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Don’t know the answer but here’s a link to the parts for a BES900 that has two .pdf diagrams showing all the parts so perhaps they may give a clue as to how to remove the drip tray.
Hopefully this is of some help until a more definitive answer comes along.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Plug on the top surface of the knob(the one that lifts the roller up). It has a screw under it.
Puan 1
Yorum Ekle
See comment below about screw under twistey knob under drainage tray. Think there's also screws in the rubber feet under the machine.
Also, If you need to get into the inside where all the boilers are, 2 screws are on the back, top they are special torx head but you can get them open with a hex. There is a third once the back upper cover comes off that gives you access to the lower part of the housing. One of these plates is attached with an earth cable, just eave it attached. Once you get the upper back panel off you may want to remove the top, this just lifts out from memory.
Puan 1
Yorum Ekle
Yanıtını ekle
Dan Casey sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 50
Her zaman: 2,133
