Ana içeriğe geç
22 Eylül 2017'de satışa sunuldu. Model A1863, A1905 olarak tanımlanıyor. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Altın, Gümüş, ve Uzay Grisi renklerinde satılır.
873 Soru Tümünü görüntüle
DIY repair gone wrong
Hi guys. I bit off a more then I could chew attempting a housing swap on my iPhone 8. Everything works fine but the bottom microphone (calls and voice memo mic). I ordered a new charging port assembly with microphone attached assuming the old was broken but same thing happened again. No voice and a horrible static noise. Have I missed something???
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
There are 4 total mics in the iPhone 8 plus. Two at the bottom on the charge port, one at the top by the ear speaker, and one by the rear facing camera.
The two on the port are used for I believe Siri and when talking on the phone using the ear speaker. When you switch to speaker phone, it uses the mic at the top by the ear speaker and I believe voice memos uses that one as well. So your next step should be to replace the front camera assembly as that is what that top mic connects to. Keep in mind that when you replace that assembly, you’ll lose TrueTone unless you can reprogram it with a special tool.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Nui sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 67
