Hi
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away.
Rice does not fix the problems caused by corrosion Rice is for dinner, not repair
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there also. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to a teardown video for the phone that may help
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later. It isn’t going to fix itself
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
4
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
4 Yorum
لدي جاهز لا يستطيع اتشغيل ابدا وماهوه الحل
Ahmad Herris tarafından
@Ahmad Herris
If the phone is water damaged see the Most helpful Answer below.
jayeff tarafından
مشكلة في اللمس
اضغط في مكان ويرتجف في مكان اخر
Omer Yousif tarafından
لا توقف فجاة من مدة طويلة
Mahmoud otaku tarafından
