Ana içeriğe geç
Device repair and information for HP's line of Pavilion 15" laptop computers.
Rumbling fan in hp laptop.
Hello everyone, I have a HP Pavilion Power 15-ec0006na 15.6 Inch Full HD Gaming Laptop. One of my fans has recently started rumbling, and I was just wandering if I have to disconnect the battery before I disconnect the fan. If so how would I do that. Thanks for your help!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Definitely, Anything that haz power supply you Always want too Disconnect Battery incase you touch something that has current u won't short the whole thing!! And the rumbling is where the motor is mounted is loose or blade/ bearing in motor is bad causing motor too vibrate,,/ Rumble… Good Luck?? Danny mechanic
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Yes. Always, always disconnect the battery first after opening any laptop.
This video may help:
https://www.youtube.com/watch?v=B4xAzVaz...
Puan 1
Yorum Ekle
Hi @astonseb5 ,
Here’s the maintenance and service guide for the laptop, taken from this webpage.
Go to p.41 to view the necessary pre-requisite steps and then the procedure to remove/replace the fans.
As @aactech stated, always disconnect the battery as soon as possible when working inside a laptop and reconnect it as late as possible during re-assembly to help minimize any potential electrical problems when working in a laptop. You don’t have to remove the battery, merely disconnect it from the motherboard (see p.37)
There is always power present on the motherboard even when the laptop is switched off. The Power On/Off switch is not a power isolating switch. It merely signals the intentions of the user to the BIOS/OS as to what is wanted. Think of the laptop as being in an extremely low power state when off and not totally isolated from the power supply i.e. battery.
Puan 1
Yorum Ekle
Yanıtını ekle
Matthew sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 381
