Ana içeriğe geç
Amazon Alexa entegreli, müzik çalmak, haberleri kontrol etmek ve diğer Alexa yeteneklerini kullanmak için tasarlanmış sesle kontrol edilen kablosuz ev ses sistemi. Sonos One yazılımı, diğer akıllı cihazlarda olduğu gibi Wi-Fi sinyali aracılığıyla güncellenir. 24 Ekim 2017'de piyasaya sürülmüştür. Model: Cihazın altında bulunan S13.
Not powering on. Likely Power Surge issue
I had a power surge in my house & 2 of my Sonos One speakers (in the same room where I noticed the surge issue) are not coming on since.
I have tried to replace the cable with a working Sonos One from another room but no joy
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
2 Yorum
My Sonos One SL's power supply died 2 months out of warranty. No support from Sonos, so I'm trying as well. Slightly different set-up. The seal on the base has two-parts: rubber and a plastic adhesive strip that covers the screws. Also, the 4 T8 screws in step 7 are covered with adhesive covering that needs to be pulled away from the chassis. I haven't removed the T8 screws yet as I don't have a T8 bit.
tarafından
Hi, I have the same problem after a power surge. Where do I get sparepart ie new power adaptor board?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Open up the speakers and check for any damage i.e. burnt out components.
Here’s the ifixit Sonos One guides that will help to do this.
I cannot find the schematics or a service manual for the speaker so finding out what the problem is, especially if it is not obvious and then replacing any faulty part(s) if their value markings have been obliterated will be difficult.
If you can’t see any obvious damage or even if you can, post some close up images of the board where the power connects to. Here’s how to do this on ifixit Mevcut bir soruya görsel ekleme
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
PC Chitalkar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 42
Her zaman: 2,853
