Ana içeriğe geç
The third generation Pixel released by Google in October 2018.
103 Soru Tümünü görüntüle
Won’t turn on after battery replacement
I replaced my Google Pixel 3 battery and then plugged the phone into a charging cable. After about 3 hours, I went to turn it on and all it did was give me haptic vibrations whenever I would touch the fingerprint sensor or power button, otherwise completely bricked. I reconnected all the ribbon cables twice and still the same issue. Any thoughts?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Considering you’re getting feedback when you touch the finger print sensor, I would say it’s possible you damaged the display while attempting your repair.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
If the phone vibrates when you plug in the charging cable that means the battery is connected. If the screen will not turn on check the cable for the screen located on the right side of the battery in the middle. It needs to be pushed down quite a bit to be connected.
Puan 0
Yorum Ekle
Yanıtını ekle
Patrick Wendler sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 802
