Ana içeriğe geç
21 Eylül 2018'de piyasaya sürüldü. A1921, A2101, A2102, A2104 Modelleri vardır. GSM veya CDMA / eSIM veya nano-SIM / 64, 256, veya 512 GB / Gümüş, Altın, ve Uzay Grisi seçenekleri mevcuttur. ("iPhone 10 S Max." olarak telaffuz edilir)
381 Soru Tümünü görüntüle
Replacement XS Max screen won’t fit. Why?
I’ve an iPhone XS Max with a busted screen. I ordered a replacement but the screen won’t fit. It has these little tabs sticking out all down right hand side but existing screen doesn’t so there’s nowhere for these tabs to slot into.
Can anyone tell me why or how to get around this please?
thanks.
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Your tabs are stuck in the phone, you have only lift up setje front of the screen and the metal frame of the screen is still inside the iPhone. You first got to get them out before you can instal your new screen.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
You’re absolutely right! Problem solved and new screen installed. Thankyou ??
tarafından
How do you take the tabs out?
tarafından
Yorum Ekle
have you ever had your screen replaced by a shop or anything?
in the guides ive seen all the replacement screens have the tabs… thats how it holds to the body of the phone.
iPhone XS Max Screen Replacement
follow that guide and see if you can get it reattached that way.
Update (03/31/2021)
heres a few more tips for getting this thing reattached
https://www.iparts-4u.co.uk/blog/iphone-...
Puan 0
3 Yorum:
No never had screen changed. Bought phone from cash converters when it was 6 months old. It was in new condition.
It’s really odd that the replacement screens won’t fit. I’ve run the serial number through Apple and it all checks out ok so I’m baffled?
tarafından
@dragon2273 only thing i can really suggest is either the phone is a REALLY good counterfeit OR there is something jammed in some of the slots where the "pins" on the screen would fit? maybe use a magnifying glass and check to see if theres gunk or something in there?
tarafından
Merci de votre réponse
si je comprends bien il faut enlever la plaque lisse qui entoure le téléphone pour retrouver les ancrages ?
je ne veux pas faire bétises
tarafından
Yorum Ekle
Yanıtını ekle
dragon2273 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 35
Her zaman: 1,710
