Ana içeriğe geç
Following the form of Lenovo's slimmer, smaller Yoga two-in-ones, the Lenovo IdeaPad Flex 5-1570 gives you great performance, using an Intel Core i5-8250U 1.6GHz processor and an integrated Intel UHD Graphics 620 video adapter.
My laptop bottom base cover is cracked and needs replacemtn
Where can I get a replacement bottom base cover for my Lenovo Flex 4 Series 2-in-1 Touchscreen Laptop . It’s cracked in multiple places and also disconnecting from the hinges. Is there a supplier that can provide replacement parts?
Thanks
Sridhar
Bu iyi bir soru mu?
Puan 0
3 Yorum
The laptop is 15.6".
tarafından
@srig
What is the full model number of the laptop as shown on the information label on the bottom of the laptop?
tarafından
@jayeff
The model number at the bottom reads:
Ideapad Flex 4 - 1580
80-VE
Thanks
Sri
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @srig ,
The parts list for your model shows that the part number for the base enclosure (bottom cover) is 5CB0L46025 (Click on Select Commodity > Covers (1) to view the part number).
If you search online using the part number only (example only) in the search term of your browser you will get results for suppliers of the part.
To replace the base enclosure you have to nearly completely dis-assemble the laptop. Here’s the hardware maintenance manual that shows how to remove all the necessary parts to do this, which should help.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
@jayeff
Thank you for the links. I used the part number and found the base cover at
https://www.impactcomputers.com/5cb0l460...
Appreciate the assistance.
Thanks
Sri
tarafından
Yorum Ekle
Yanıtını ekle
Sri sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 1,037
