Ana içeriğe geç
The fourth-generation Surface Pro tablet, released October 26th, 2015.
208 Soru Tümünü görüntüle
Backlight comes on, but no display after changing battery?
I just replaced the battery in my old Surface Pro 4. After reassembly, the device powers up and the backlight comes on, but nothing comes up on the display. I have connected it to an external monitor and confirmed that it is booting to the OS. I have also confirmed that the touch functionality is still working, by mirroring the main display with the external.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
If I’m not mistaken, when you disconnect and reconnect the battery in certain surface models, it blows a fuse for the image circuit. That or you could’ve damaged the display.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Have a detailed look at the connector under the microscope. I‘ve had no touch and found a stucked pin inside the connector on the board. Maybe this is the same with your connector.
Puan 0
Yorum Ekle
Did you solve your problem?
I'm having the same issue, i get a subtle backligth but no image. Maybe related to a damaged ribbon flex cable?
Puan 0
Yorum Ekle
Yanıtını ekle
Terry Laurent sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 79
