Battery status changed from "Replace Now" to working ok
Hi, My Macbook Pro Late 2011 suddenly had charging issues. The battery would not charge and the charging light was a constant green on the Magsafe charger. Macbook would not load past boot screen, I tried a list of things to try fix issue including resetting NVRAM but long story short, the only way I could use the machine was by using it in Safe Mode. (Also, battery status on screen was showing "Replace Now"). I got by for about a month using Safe Mode, but the battery was still the same: Not charging. I could only ever use the Macbook while it was connected to charger. If i accidentally disconnected the charger from the Macbook, the machine shut off.
Fast forward about a month, I again, accidentally disconnected the Charger from the Macbook, but this time the Macbook stayed on. The battery was holding its charge. I restarted the machine, it booted normally without issue, and there is no "Replace Now”on battery status. Everything seems to be as normal, battery discharging/charging as it once was.
Is this a battery issue or something like a DC charging port issue?
The issue seems to have resolved itself for now, but I would like to know how to prevent it happening again. This is the second time this scenario has happened within 6 months.
The battery itself is a third party battery, but only just over 1 year old, and was given proper attention when first installed.
MacBook Pro (15-inch, Early 2011), High Sierra, 2.2 GHz Intel Core i7
Thanks.
Bu iyi bir soru mu?
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
Dan tarafından
