Ana içeriğe geç
Ryobi matkaplar için onarım rehberleri, kullanım kılavuzları ve sorun giderme yardımı. Ryobi matkabınızı kendiniz tamir etmek için ihtiyacınız olan her şeye ulaşın.
Where to start? Ryobi LSD120
I have a very old compact drill that has served me very well. But it’s died. I would like to fix it. I have recharged both batteries and swapped them out: nothing. It was working ok then just stopped - no sign of anything going wrong beforehand. Where do I start with identifying what’s wrong? Any suggestions as to most likely causes of the problem?
Bu iyi bir soru mu?
Puan 0
2 Yorum
Used carbon brushes, corroded battery terminal or faulty trigger switch would be my first bet
tarafından
Thanks for your suggestions. I'll test the batteries then move on to these.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The above answer is assuming the batteries are actually good, which is the first potential cause. They may appear charged but have such high internal resistance that you can’t get enough current out of them. Try testing them with a resistance load and a multimeter.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thanks, I'll test that. I think it unlikely that this would happen with two batteries simultaneously, but I'll rule it out first.
tarafından
Hi there. I also have Ryobi LSD-120 drill with two batteries. If the batteries fail to charge, it will probably mean the voltage of the batteries has dropped too low ! You could try to "jump start" them with a 12V battery charger, for a few seconds, but that would only be a temporary fix.
You can buy new batteries from Ali express in China for only $16 US. each at the moment Ken T.
tarafından
Yorum Ekle
Yanıtını ekle
RoNZ sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 416
