When I lift my screen all the way up theres a green tint.
When i lift it down a little it goes to normal.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
It may be a loose display cable connection at either end, motherboard or display panel or perhaps the display cable is damaged where it passes through the right hinge to get from the lower case to the lid.
Here’s the maintenance and service guide for the laptop, taken from this webpage.
Go to p.37 to view the necessary pre-requisite steps and then the procedure to remove the display assembly.
This will allow you to initially check the display cable’s motherboard connection and if OK you will have to remove the display assembly so that you can check the connection at the display and also the condition of the cable where it passes through the hinge. Note: take heed of the warning regarding the removal of the screen bezel during the procedure.
If the cable is damaged then on p.12 Item #5 you will find the spare part numbers. Search online using the part number only (appropriate to your particular device) to get results for suppliers.
If doing all this seems too daunting, contact a reputable, professional laptop repair service and ask for a quote.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 138
